Order Ford 4000 Parts Online
Ford 4000 losing pto power, need suggestions pleas
Audrey Zoog
06-16-2003 09:21:28
Hi, I have a Ford 4000 that I use to cut hay with a 6 1/2' disc mower. After a couple of hours cutting, it loses pto power and will not give the mower enough power to cut. If I then let the tractor set overnight the next morning it works great again for a couple-three hours before repeating the cycle. Could it be because it is getting too hot? The guage doesn't say that it is but this is the only thing I can come up with. Any suggestions would be greatly appreciated!
Thanks,
Audrey Zoog
RickB.
06-16-2003 14:58:02
 Re: Ford 4000 losing pto power, need suggestions p in reply to Audrey Zoog, 06-16-2003 09:21:28
If it is a 3 cyl 4000 with independent PTO sounds as if the clutchpack piston seals are giving up. When the oil gets hot & thins, the clutch won't lock up fully. By now you need clutch discs and plates, too. A rear split is required. If it is a 4 cylinder 4000, the PTO disc may be getting oil on it and slipping when hot. But I bet you have a 3 cylinder tractor.
Audrey Zoog
06-17-2003 08:03:04
 Re: Re: Ford 4000 losing pto power, need suggestio in reply to RickB., 06-16-2003 14:58:02
Thank you for your reply--it is a 3 cyl diesel. What you describe sounds very plausable. How big of a job is it to split the rear-end? We do have all the service manuals that tell you how to do all the repairs and my husband and dad are pretty good at mechanics, but would it be something that the dealership really should do? Thank you again!
Audrey Zoog
Al
06-16-2003 21:24:44
The early 4 cyl. 4000 does not have a disk pack for the pto.It's directly coupled to the tranny.
RickB.
06-17-2003 14:39:40
 Re: Re: Re: Ford 4000 losing pto power, need sugge in reply to Al, 06-16-2003 21:24:44
Right, but either clutch disc can get oiled, causing it to slip.
paul
06-16-2003 10:47:36
I was thinking your pto itself was losing power, like a slipping clutch.
But then you say the engine might be overheating?
So, is the whole tractor losing power, or just the pto shaft?
If it's gas engine, it could be overheating the fuel & vapor locking.
--->Paul
Audrey Zoog
06-17-2003 08:06:04
 Re: Re: Ford 4000 losing pto power, need suggestio in reply to paul, 06-16-2003 10:47:36
Thank you for your reply! It seems like just the pto is losing power--the hydraulic arms seem to work fine and the tractor runs fine as well. It is a 3 cyl Diesel ~1965 model. Thank you again for your reply!
Audrey Zoog
