Order Ford 3000 Parts Online
3000 Ford Diesel Engine Oil
johnson
06-22-2003 23:11:27
What is the best brand and weight of engine oil to use in the diesel engine? Normal weather temp from 30 degree or less to 100 degree plus. Thanks in advance.
hvw
06-23-2003 02:59:21
 Re: 3000 Ford Diesel Engine Oil in reply to johnson, 06-22-2003 23:11:27
You want to use 15W-40. I use Chevron.
TimK
06-23-2003 12:16:56
 Re: Re: 3000 Ford Diesel Engine Oil in reply to hvw, 06-23-2003 02:59:21
The oil must be diesel rated. I also use 15-w-40.
bill
06-23-2003 18:03:12
 Re: Re: Re: 3000 Ford Diesel Engine Oil in reply to TimK, 06-23-2003 12:16:56
be sure to use an diesel rated oil that is either ch-4 or the newer ci-4 rated.. chevron delo, shell rotella and mobil delvac are examples of excellent diesel rated oil availible at most wallmarts for about $6 a gallon for 15w-40.. these oils are designed specifically for heavy duty diesel operation and will meet all diesel specs and gasolene specs as well..
good luck ... bill
D. Miller
06-23-2003 18:26:21
 Re: Re: Re: Re: 3000 Ford Diesel Engine Oil in reply to bill, 06-23-2003 18:03:12
I have used Shell Rotella for years in all of my diesels with no problems.I have always used 15/40
