SOS Flush
Arlie
06-23-2003 04:31:28
I have a 1964 Ford 4000 with SOS. Could someone tell me what would be a good flush to use for the transmission?
Fighting suburbia in NC
06-23-2003 05:09:28
 Re: SOS Flush in reply to Arlie, 06-23-2003 04:31:28
If you have junk in the bottom of the case the only way to get it out is just dump some fluid in the top cover and let it go straight through and out the drain. I do not know of a "flush" that can be run through an SOS.
My recommendation is to do two changes back-to-back. Leave the old filter in for the first clean refill but change it before putting the last fluid fill in. The first new fluid will get the crud suspended (both good and bad can occur doing this) and will carry it out when you dump it. The second fill will then not have as much crud to suspend and should be OK for long term use.
Just my .00000 2 dollars worth.
