3pt Hic cups
Jim H.
06-24-2003 21:10:35
I have a Ford 640, What is causing my hydralics to jump up or some have called it hic cups.,Thanks.
Phil (VA)
06-25-2003 06:58:26
 Re: 3pt Hic cups in reply to Jim H., 06-24-2003 21:10:35
Could be the valve on the very front of the lift cover. I think it is the safety valve, but not positive of name (manual not handy here). Has spring and detent ball at bottom. I would suspect that. Might just be problem with spring or detent ball.
Larry NCKS
06-25-2003 02:27:58
Most tractors this age do hiccup to some extent. Typically a leak in the lift piston o-ring or one of the valves. I would not think this would be worth your time to try to remedy, unless it's really severe.
gatractorman
06-25-2003 15:03:05
 Re: Re: 3pt Hic cups in reply to Larry NCKS, 06-25-2003 02:27:58
I found your statement to be very true I was recently working on a 600 with this same problem, going from the IT book I done everything it said with the exception of the control valve and bushing, New Holland wants $400 for a new valve and bushing my customer decided he could live with a few hiccups.
