3 cylinder crank pulley
cdmn
06-27-2003 12:39:35
The front pulley on a 4000 gas got broken. I thought I could just pick up a used one. Are the pulleys for the 2000,3000,4000 the same? Are they the same for gas or diesel? I'm worried that I shouldn't do this because it looks like the pulley is used to balance the crankshaft. Seems like the pulley and crank should never be separated. So I guess I'll try to get the original brazed up, so the crank stays more or less balanced. What do you think?
