Order Ford 4000 Parts Online
4000 4cyl- identify casting numbers
underdog
03-08-2001 21:29:44
I would like to know if there is a source to identify the engine, transmission, & differential
casting numbers for a build year. Model & serial numbers are gone. Thanks
Tony Jacobs
03-08-2001 21:52:22
 Re: 4000 4cyl- identify casting numbers in reply to underdog, 03-08-2001 21:29:44
I can tell you what you have if you post what numbers you have , I know them only because I have been working on them all my life , but I do not know of a printed source for them , and I have most of every piece of Ford Literature printed for the 1953 -1965 tractors . Thanks Tony Jacobs
Underdog NM
03-10-2001 07:34:50
 Re: Re: 4000 4cyl- identify casting numbers in reply to Tony Jacobs , 03-08-2001 21:52:22
Tony, I have these numbers. I hope they are ones
that will help.
Engine-CONN 6015J
SOS Trans-C3NN 7006-B A265
Differential-CONN 6015J
This is a friend's Row Crop tractor. You have helped me before, so again, Thanks.
Tony Jacobs
03-10-2001 16:32:29
 Re: Re: Re: 4000 4cyl- identify casting numbers in reply to Underdog NM, 03-10-2001 07:34:50
The Engine casting number is correct 61-65 , but I need the date , it is the left side just above the oil pan rail at the front of the block . The S-O-S is a Direct clutch model (the better one) Jan. 26 1965 . The rear housing should be CONN-4024-B I think you better double check , the date will be under the casting number . Was there a serial number and model number on the trans or was it blank like some warranty trans are or was it eaten away from battery acid ? Thanks Tony Jacobs
Underdog NM
03-10-2001 18:23:47
 Re: Re: Re: Re: 4000 4cyl- identify casting numbers in reply to Tony Jacobs , 03-10-2001 16:32:29
OOPS, yes that was the wrong differential #.
Correct diff# 312478. Will look for engine date code soon. Thanks.
