Order Ford 4000 Parts Online
4000 Ford with a bad rod journal
Andy
07-01-2003 10:48:24
I bought a 4000 ford (gas) with a freeman loader from a friend. It had spun a rod bearing, but after I cleaned the bearing facing off the rod journal it looked real good. I put a new bearing in and it ran good, but after about 15 hours use it started making a little noise, so I put another bearing in and had the same results. I guess it needs to be torn down and have the crank ground. The tractor is supposed to only have about 1300 hours on it. I don't have the time or money to mess with it right now, so I was wondering if someone could tell me about what I should ask for the tractor the way it is. It has like new tires all the way around, wheel weights, good power steering, 8 speed trany, good pto and hydraulics. The loader has a couple of welds, but works good. Thanks Andy
Andy
07-01-2003 10:51:45
 Re: 4000 Ford with a bad rod journal in reply to Andy, 07-01-2003 10:48:24
I forgot to mention that the year of the tractor is 1970. Thanks again, Andy
Andy
07-01-2003 10:49:52
I forgot to add that the year of the tractor is 1970. Thanks again. Andy
