Order Ford 3000 Parts Online
3000 diesel water pump?
Mark R.
07-02-2003 11:27:31
The water pump on my 3000 diesel has to be replaced (leaking big time). My question is; Does the radiator have to come off to replace the water pump? I would appreciate the benefit of your experiences. Thanks, Mark R.
bill
07-02-2003 13:12:43
 Re: 3000 diesel water pump? in reply to Mark R., 07-02-2003 11:27:31
yes.. its almost impossible without pulling the radiator or fan shroud..
now is the time to..
replace your hoses..and belts.. flush the radiator and add new antifreeze... and all this is easier to remove the hood and cowl on the 3000 series.. be sure to clean the air passages on the radiator as well.. then your good for another 40 years...
good luck.. Bill
Mark R.
07-03-2003 20:20:33
 Re: Re: 3000 diesel water pump? in reply to bill, 07-02-2003 13:12:43
Bill, thanks for your help. My uncle and I changed the water pump today. We managed to get it done and did not have to take the radiator or fan shroud off. It was close, but it workled OK. We used the blue silicone (just a film coat) on both sides of both gaskets. I really appreciate your help, and yes we did change all the perishable parts in the process. Thanks, Mark R.
