I hope I can remember everything, but maybe someone else will correct any oversight. I needed: O rings for the lift cover plate that covers the cylinder bolts and the pressure relief valve (7 of them?). A gasket and two O rings for the lift cover itself. I got an extra lift cover gasket, because the cover is heavy to lift and I was worried about tearing the gasket while trying to get everything aligned. An O ring and backing washer for the hydraulic piston (my washer was nylon rather than leather). A gasket for the end plate that holds the control and unloading valves in. New cam follower pin. Hydraulic oil. Gasket compound to help hold gasket in place. Gasket scraper/wood chisel, Emory cloth, & PB Blaster/penetrating oil. I got my parts at the NH dealer, because some have reported that aftermarket O rings don't seal properly. Feel free to email if I can be of any more help: mhurwitch@engineer.com
