Order Ford 4000 Parts Online
4000 gas that gets hot
alan
07-08-2003 06:10:34
I have a 4000 ford with the 201 gas engine. After about 20-30 minutes the exhaust and manifold get so hot they start to glow. Is this normal? If not what could be causing it. Thanks. Alan
Lee
07-08-2003 12:40:36
 Re: 4000 gas that gets hot in reply to alan, 07-08-2003 06:10:34
That's not normal for them to glow. You may have an intake air leak causing too lean of a mixture. You can check that with a can of carb. cleaner. With the tractor running spray the carb cleaner around the intake portion of the manifold and the carb base gasket. If it's leaking you'll hear a change in engine speed when you spray the leak.
Good Luck, Lee
alan
07-08-2003 13:59:13
 Re: Re: 4000 gas that gets hot in reply to Lee, 07-08-2003 12:40:36
Thanks for the info Lee. I will check it out.
Alan
