Order Ford 8N Parts Online
1950 8n crank pully
capt. needs hel
07-09-2003 19:05:34
i have an 8n with a loose crank pully. i`m told its held in place with a 15/16 nut. guess what? mine ain`t got no nut. how do i remove the pully?any advice would be most helpful.
Rick H. Ga.
07-10-2003 04:51:37
 Re: 1950 8n crank pully in reply to capt. needs help, 07-09-2003 19:05:34
A special bolt made to accept a hand crank secures the pulley. It doesn't look like a bolt from visual observation but the hex head is back behind the hand crank protrusion. If the hand-crank/pulley bolt is missing altogether you will need to get another one. HTH. Rick
big joe
07-09-2003 19:14:36
i took mine off my 9n. it just pulls off. use a puller
