Order Ford 3000 Parts Online
Live Power On 3000
Bob C
07-12-2003 08:49:00
Been looking for a 3000 Ford and found one at a great price but hte gentleman that has it says it doesn't have live power. Well I thought all 3000's had live power am I right or am I mistaken. It's a great running tractor(diesel) and sure enough as it sits the PTO doesn't continue to turn when the clutch is depressed and the lift doesn't work unless the lever is engaged. Works just like my 8N with no live power.What do you all think is going on here?
Bob C.
AB-NY
07-12-2003 09:59:29
 Re: Live Power On 3000 in reply to Bob C, 07-12-2003 08:49:00
Mistaken. Four speed trany driven PTO shaft just like your 8N. Find the Hi/Low trany model and you'll have a 2 stage clutch as standard. AB
Bob C
07-12-2003 18:44:56
 Re: Re: Live Power On 3000 in reply to AB-NY, 07-12-2003 09:59:29
Are you saying that if it has a high low transmision then it has live power? This tractor does have the high low stick but the PTO still doesn't respond as it should. Now maybe it is not working for some reason so I think I should investigate a little deeper into this matter and maybe not get too excited about this tractor.
Bob C.
RWK in WI
07-12-2003 20:09:06
 Re: Re: Re: Live Power On 3000 in reply to Bob C, 07-12-2003 18:44:56
If it has a 4 speed single range transmission or a six speed dual range transmission it has transmission PTO.
If it has a 8 speed dual range transmission and a single stage clutch it has transmission PTO
If it has a 8 speed dual range transmission and a dual stage clutch it has Live PTO
All were options on 3000's. I hope this helps you.
