Friend has a PTO prob. on a 500
ALAN
07-13-2003 20:58:28
Usually over at the Massey Board... hope that won't count against me... I have a friend I'm trying to help out. He has a Ford 500 with the PTO sticking out 6" further than the norm. Are these just like the Massey's (which have a clip ring just inside the retainer plate) or are they different? Any tricks to getting the old one out or do they come straight out with no problems? The closest Ford dealer just went out of business so he'll hafta drive 2.5 - 3 hrs to get the parts (wanna make 1 trip) anything esle that should be done while we're in there? Thanks for the help - ALAN
Holder-MEM
07-14-2003 20:42:30
 Re: Friend has a PTO prob. on a 500 in reply to ALAN, 07-13-2003 20:58:28
There is a snap ring on the shaft just inside of the bearing. It is what keeps the shaft from working out. Six inches would mean the snap ring has broken or slipped off. Drain the fluid from the rear end and the hydraulic reservoir. Then remove the four bolts holding the pto housing to the rear end. The assembly should slide out. You may get lucky with a simple snap ring replacement.
Make sure the pto seal sleeve is pressed close enough to the bearing that the snap ring barely has room to snap in the shaft groove.
ALAN
07-15-2003 19:11:04
 Re: Re: Friend has a PTO prob. on a 500 in reply to Holder-MEM, 07-14-2003 20:42:30
Thank you, I will start on the project next weekend. Most of the oil has already drained out (when the shaft came past it's seal area). He's ordered a seal and snap ring already. One more question, are Fords finiky about their oil like Fergusons & MF? If so, is there an accepted sub or should we go only with the OEM oil?
Holder-MEM
07-15-2003 21:20:09
 Re: Re: Re: Friend has a PTO prob. on a 500 in reply to ALAN, 07-15-2003 19:11:04
You will find mixed opinions on the lubricant. We rarely use our 8N or 841 in the winter, so we use the 85-90 weight GL-5 lubricant (rear end grease) in the tranny, hydraulics, and rear end reservoirs. Other folks will use the lighter weight lubricant New Holland sells. If you use the tractor in winter, the NH stuff may serve you better.
