Order Ford 640 Parts Online
640/cutting out and backfiring/ Help
Ben.So.Tex
07-19-2003 18:53:32
My 640 was doing fine while was shredding grass today and it started to miss, I cleaned the fuel bowl and drained the carb, because I thought it might have water in it..still missing ,,Now it starting to back fire and shoot fire out the tail pipe,, I have not check the cap for moisture,, All of my tractors are kept in a shed. I just gave it a tune up about two months age.. what can it be BEN
John IA
07-19-2003 21:01:14
 Re: 640/cutting out and backfiring/ Help in reply to Ben.So.Tex, 07-19-2003 18:53:32
Ben, I'd check for moisture in the cap, The little spring clip in the bottom of the rotor may have broke,letting it move freely. A coil going bad or maybe a worn gear on the distributor. Good Luck John
