Order Ford 600 Parts Online
Ford 600 5-Speed Transmission Problems
Bill Fraize
07-21-2003 06:39:06
Can you help me with a problem or know of someone who could. I have a Ford 600 tractor. Last year I had a rebuilt motor and new clutch installed. Now the 5 speed transmission is giving me a problem. It is stuck in 4th gear. I removed the transmission cover and it seems the 4th gear is locked or jammed tight on the counter shaft even though the shifters are in neutral. The tractor is excellent condition and I do not want to junk it. Any help or suggestions?
Jeff Stevens
07-23-2003 20:47:34
 Re: Ford 600 5-Speed Transmission Problems in reply to Bill Fraize, 07-21-2003 06:39:06
Bill, I just fixed the same problem. The slip yoke for 4th &5th gear has 2 small ears on it, and one of them broke off. It's not hard. You split the tran's in front and in back. Then you have to pull the top row of gears out to get to the yoke. About $80.00 later your ready to go ..Hope i could help! Jeff Stevens
