Order Ford 2000 Parts Online
changing fluids in 2000 offset 1964 model
ANTHONY B
07-30-2003 18:40:00
NEEDING INFO ON CHANGING OIL WHAT WEIGHT OF OIL.ALSO CHANGING TRANMISSION FLUID NEED TO KNOW WHAT TO USE.THIS TRACTOR ALSO HAS HYDRALIC FOR THE ROW CROP WASNT SURE WHAT KIND OF FLUID FILLS THE CYCLINDERS.I HAVE NO MANUALS ON THIS TRACTORSO I DONT KNOW WHAT TO USE OR WHERE TO START TO TUNE THIS MACHINE UP PROPERLEY.IF ANY ONE CAN DIRECT ME TO SOME SERVICE AND PARTS MANUALS I WOULD SURELY THANK YOU.I DONT WANT TO ORDER PARTS AND THEY NOT BE RIGHT.THANKS A LOT
ATW/WA
07-30-2003 20:27:34
 Re: changing fluids in 2000 offset 1964 model in reply to ANTHONY B, 07-30-2003 18:40:00
Anthony, Upper left hand corner this page under Marketplace, you'll find tractor manuals. search ford 2000.
ATW/WA
anthony b
08-02-2003 15:40:25
 Re: Re: changing fluids in 2000 offset 1964 model in reply to ATW/WA, 07-30-2003 20:27:34
just wanting to make sure i get the right manuals to serice and order parts for this offset tractor .not wanting to spend a lot of money on manuals if they are not the right ones
ODDBALL TRACTORS
08-03-2003 16:15:56
 Re: Re: Re: changing fluids in 2000 offset 1964 mo in reply to anthony b, 08-02-2003 15:40:25
Anthony, I understand your concern and issues now. As for fluids, tune up parts and specifications, the requirements should be the same as the standard tractor. The majority of the power plant, drive chain and hydraulics will be the same as a conventional tractor. Engine: 4cylinder gas, LP or diesel. Transmission: 4,5 speed or Select-O-Speed(SOS) Where your true concerns will come into play is with any parts associated with the "Offset" features this tractor has.
At this point, rather than rely on memory, I'll ask that you email me back so I can check reference materials.
HTH
ATW/WA
PS. Hope the response heading will draw futher interest from other members of this forum.
ANTHONY B
08-04-2003 18:12:31
 Re: Re: Re: Re: changing fluids in 2000 offset 196 in reply to ODDBALL TRACTORS, 08-03-2003 16:15:56
THANKS FOR YOUR HELP .I WILL E-MAIL YOU .OUNCE AGAIN THANKS FOR EVERY REPLY
