Order Ford 860 Parts Online
HELP!! 860 overheating
Bill in NC
08-12-2003 07:15:41
Trying to fix my overheating problem. Can bush hog for 1 1/2 hr before it goes into red. I have replaced the radiator cap, theromstat, and lower hose, drained radiator (anti-freeze was a nice green color, no sediment). Still overheats what is my next step?
I have a cracked manifold, could that be it, or the water pump. Water pump age ????
Also I can squeeze the lower hose and it doesn't seem like there is much water there. Does this mean a bad radiator? No leaks that I can see anywhere. With cap off I see a lot of vibration but not much water flow.
Jerry/MT
08-12-2003 11:06:55
 Re: HELP!! 860 overheating in reply to Bill in NC, 08-12-2003 07:15:41
Bill:
If your not seeing much water flow with the cap off and the engine warmed up, check your water pump drive belt to make sure it's driving the pump. If that's OK, check the thermostat to make sure it's opening. Hope this helps.
MT Mich
08-12-2003 10:22:02
Bill, going through exactly the same thing on my 861 right now. Mine didn't get to red, but got close enough to bother me. Running Prestone flush in it right now (probably change out this weekend). Also, thought I had the rad cleaned out good with air, but after flushing from fan side with water, then blowing again real careful I got a lot more junk from between the fins. Not sure if I'm fixed yet either...
Rick Bishop
08-13-2003 08:08:08
 Re: Re: HELP!! 860 overheating in reply to MT Mich, 08-12-2003 10:22:02
I would take a close look at the radiator fins. Pollen, dust, weeds, bugs etc. can build up and take a lot of back flushing from the fan side to get out. I have been brush mowing for the past week and have had an extra screen over the raditor. It cleans faster but still gathers a lot of debris.
Fred
08-12-2003 09:52:13
Does it over heat if not mowing? Often the front of the radiator gets so loaded with chaf that the cooling is greatly affected. A screen in front or right behind the grill will solve that problem. Also a good radiator hosing from the back side to flush out the cooling fins helps. Fred.
