SOS Transmission Filter
BOB (WA)
08-19-2003 14:50:18
What is the correct fluid flow for the transmission filter located inside the case next to control valve assembly? I believe this is a filter for the return fluid so the outlet should be facing down toward the sump.
Thanks
Bob
Larry NCKS
08-19-2003 17:31:24
 Re: SOS Transmission Filter in reply to BOB (WA), 08-19-2003 14:50:18
you are correct. The outlet should attach to the drain tube, the bottom of which clips on a web in the case.
Bob (WA)
08-20-2003 13:11:12
 Re: Re: SOS Transmission Filter in reply to Larry NCKS, 08-19-2003 17:31:24
Larry Thanks for the fast response.
Bob
Mike
08-21-2003 08:52:06
 Re: Re: Re: SOS Transmission Filter in reply to Bob (WA), 08-20-2003 13:11:12
Bob,
Where were you able to find the filter? My local NH dealer claims he can't get them. Thanks.
Mike
BOB (WA)
08-21-2003 11:33:41
 Re: Re: Re: Re: SOS Transmission Filter in reply to Mike, 08-21-2003 08:52:06
I purchased mine from NH dealer Coastline Tractor 3512 Smith Avenue Everett Washington 98201 (425) 259-7181. They had one in stock which I received the next day UPS.
Bob
