Order Ford 801 Parts Online
Ford 801 6v and 12v wiring diagrams
Brandt
08-19-2003 16:41:27
I have read numerous posts but have not found a detailed wiring diagram for the 6v systems or for the converted 12v system.
Could someone email, post, or direct me to a websit or book with one.
Thanks
Brandt
Jim.UT
08-20-2003 11:34:26
 Re: Ford 801 6v and 12v wiring diagrams in reply to Brandt , 08-19-2003 16:41:27
third party image
The original 6V wiring diagram that used to be on the Vintage Ford Tractor Resource page (linked elsewhere in this thread) does not come up for some reason. I have it saved on my hard drive. Here it is.
Matt S
08-19-2003 19:44:55
check out the following page or www.geneseeproducts.com
good luck
George H
08-19-2003 22:37:20
 Re: Re: Ford 801 6v and 12v wiring diagrams in reply to Matt S, 08-19-2003 19:44:55
Check the 6-volt Hundred series positive ground diagram on page 5 or 6 in the post '860 wiring schematic?'. I don't believe Ford ever printed an updated Hundred-and-one series 6-volt diagram.
Changes from *00 to *01:
1)generator warning light instead of ammeter.
2)ammeter replaced with fuel gauge.
3)4-post starter relay instead of 3-post--relay power is from the terminal block.
The 12-volt negative ground diagram for diesel tractors is at the link. Wire a 6-volt *01 with the 6-volt diagram and use changes from the 12-volt.
should have added...
08-19-2003 22:42:30
 Re: Re: Re: Ford 801 6v and 12v wiring diagrams in reply to George H, 08-19-2003 22:37:20
that everything in the 6v/12v post is for original Ford wiring and unrelated to 12-volt alternator conversions.
firedog
08-20-2003 11:39:04
 Re: Re: Re: Re: Ford 801 6v and 12v wiring diagram in reply to should have added..., 08-19-2003 22:42:30
You can go to the Ford Forum Archives here or go to The Vintage Ford Tractor Resource at www.hometown.aol.com/naa60512/naa.htm
firedog
