Order Ford 841 Parts Online
841 Diesel Flywheel
44
09-09-2003 10:46:55
I have a good diesel motor off a 841 ,single clutch
I would like to put the diesel on my 860 gas ,gas motor is bad.
Queston can i use the gas double clutch & flyweel
on the diesel engine. with out any problems.
I know I would have to change the fuel tank & the trottle linkage Or did I miss something I think I have all the parts I need on hand.
Horseman
09-11-2003 06:09:24
 Re: 841 Diesel Flywheel in reply to 44, 09-09-2003 10:46:55
Try your local ford newholland dealer and look up the part#'s. See if they are Dif. Were did you find a good 172cu diesel engine? They are getting kind of rare. Good luck WRP
Royce Tn
09-10-2003 17:02:17
I consulted my 1955 - 1960 Ford manual and could not find any conclusive evidence that it would not work. However, I'm no expert. The 172 cubic inch Diesel Engine was built on the Gas version block so it should bolt right up. As you said, you have lots of "plumbing" to connect the fuel system.
