Order Ford 600 Parts Online
'78 Ford 3600 Main Spring Adjustment
M.J. Goebel
03-16-2001 19:51:40
Can anyone help me with the main spring adjustment on my Ford 3600. The spring is very loose, probably 1/2 to 3/4 inch of play. Lift seems to work just fine though.
Chris Mavrelis
07-09-2006 06:51:08
 Re: '78 Ford 3600 Main Spring Adjustment in reply to M.J. Goebel, 03-16-2001 19:51:40
PLease send me pics of your Ford 3600 Tractor as to help me identify my 3600 tractor.
Bern
03-16-2001 22:54:31
Turn the end cap in until all the play goes away.
M. J. Goebel
03-18-2001 06:55:27
 Re: Re: '78 Ford 3600 Main Spring Adjustment in reply to Bern, 03-16-2001 22:54:31
Thanks Bern, I tried that and it doesn't seen to want to get tight enough to put pressure on the spring. It's close but seems to be bottoming out. Could the previous owner have left it too loose for too long and damaged something internally?
Bern
03-18-2001 08:34:15
 Re: Re: Re: '78 Ford 3600 Main Spring Adjustment in reply to M. J. Goebel, 03-18-2001 06:55:27
Could be rust and/or corrosion on the threads preventing you from turning it in far enough. Try turning it counter-clockwise until it comes all the way out, inspect the threads and clean as needed, put some anti-seize lubricant back on the threads, and try over again.
M.J. Goebel
03-18-2001 16:33:06
 Re: Re: Re: Re: '78 Ford 3600 Main Spring Adjustment in reply to Bern, 03-18-2001 08:34:15
Will do, thanks for the info Bern.
mjg
