Order Ford 4000 Parts Online
4000 lift problem
Bill B.
09-29-2003 20:46:23
I am having problems with the lift on my ford 4000. I put a bush hog on it and it is ether up or down there is no in between. This is ok hauling hay but not for bush hogging. Any help would be appreciated.
Bill B.
09-30-2003 18:19:03
 Re: 4000 lift problem in reply to Bill B., 09-29-2003 20:46:23
Thank you for your idears. I will make sure i have everything in the right position tomorrow.
hvw
09-30-2003 16:08:21
Rod made the right suggestion. Always check the obvious stuff first. However, with my luck such as it is, I've found that when my tractor breaks down, if I go to the most expensive or hardest to find part or the most difficult repair....that's where the problem invariably is. Good luck!
Rod F
09-30-2003 06:30:09
Hi Bill
Before you rip the cover off, make sure you have the system selector in position control (lever up), and not in draft control. Draft will cause the symptoms you describe. Otherwise, some internal repair/adjustment is needed. Just my thoughts.
Rod
hvw
09-30-2003 02:37:31
Bill, the cam follower pin in the lift cover may need replacing. If it does you might as well rebuild the cover while you're there.
