Wheel weights for a blue ford?
Bill Oakes NY
10-06-2003 05:55:36
I have a 1970 4000SU. Rear axle has 8 lug bolts, spaced farther apart than the 601/801. Also has 24 inch rear wheels, 16.9x24 to be specific. What kind of wheel weights were made for this tractor? I think the pie weights won't fit because of the larger bolt pattern. What can I use?
tom
10-08-2003 04:35:46
 Re: Wheel weights for a blue ford? in reply to Bill Oakes NY, 10-06-2003 05:55:36
i have rear wheel weights for your Ford 4000
RickB.
10-06-2003 17:55:45
Your tractor probably uses a donut shaped weight using a 4 bolt mounting pattern. They aren't terribly heavy, less than 100# per piece, I'd guess. This weight fits most Fords with wet brakes and pressed steel centers on the rear.
