So, I posted a while back as a newbie looking for tractor options. I settled on a nice 1955 960. Seemed to fit my needs, and it came from a Ford fanatic about 5 miles from home.I bought the manuals, and pored through them. Even so, I didn't see a specific step-by-step procedure on how to change the oil on the final drive boxes, and what kind of oil to use. The fella I bought the tractor from said to use 120 wt gear oil. Can I use a Mobil DTE Extra Heavy or a Mobil Gear 629? What is the recommended viscosity for oil in those final drive boxes? Now, can anyone give me the step by step for draining and refilling the final drives? On to other questions: If I understand this correctly, the tractor is divided into 3 parts: the engine, the tranny, the rearend/hydraulics. Of course engine oil goes into the engine (30 wt?). Now, hydraulic oil goes into both the tranny and the rear end? What hydraulic oil properties am I looking for? Do you guys generally use Ford branded oil? I like the Mobil 13M hydraulic oil, would this be good for my tractor? I have remote hydraulics on my tractor. The lever and hoses are under the seat. One of the fittings is leaking a little bit, so I pulled it off to see what the deal is. I was expecting a crush washer between the fitting (that square fitting attached to the end of the hose) and the distribution box on the tractor. There was none...is this correct? Also, where would I source the rubber gaskets on the top of the fitting through bolt? Power steering pressure side hose. Where would I get one of those? Just bring it down to the NAPA and have them make me one up? Also, my power steering pump reservior (the round reservior on top of the pump) does not have a filter in it. I see in the manual that a filter goes in there...I assume I'm missing it, where would I get one? I want to leave the 6 volt system intact. I see that there are electronic ignition kits for 6 volt systems. Are they worth it? The best engine improvement I made to my 73 VW Thing was EI. Does EI help the tractors as much too? That's it for now. If you read all the way to here, thanks. Bob East Hampton, CT
