Change motors and rear-ends
AL
10-11-2003 18:58:21
I have two Ford 3000 diesels. One is a 3400 and have a heavy duty front-end, new tires and a very good motor, but has a single-stage clutch, ratchet on the power take off, and power steering.
The other is a 3000 with a duel- stage clutch and no power steering.
I am considering splitting both tractors at the motor and transmission, connecting the 3400 motor and front end on the 3000 transmission with the duel-stage clutch.
And then connecting the 3000 motor and front-end with the 3400 transmission.
Does anyone see a problem with this. I think it will work
Gary-Miss
10-11-2003 21:00:43
 Re: Change motors and rear-ends in reply to AL, 10-11-2003 18:58:21
It'll work. Pay attention to the differences as you take them apart. You even haveto change clutch pedals, things like that. It's been several years for me. I changed all of the way to the rear end. I even had to use a chopsaw to shorten the coupling in the driveshaft.
