Ford engine casting codes
Bob Oakes
10-21-2003 12:47:52
I know casting code EAE signifies the 134 cubic inch engine and EAF signifies the 172 cubic inch engine used in the 600&800 series tractors. I resently saw a 861 and a 681 that had no letters on the engine at all. How else can you tell the difference between them? Thanks, Bob
Bob Oakes
10-22-2003 06:54:10
 Re: Ford engine casting codes in reply to Bob Oakes, 10-21-2003 12:47:52
Scott, Thanks for the information. The tractor I'm looking at has a engine casting code of 310609 but has no letters in front of it like I have seen on other engines. Your info would make it a 57-59 but how can I tell if it is a 134 or a 172 cubic inch. It is a 861 and should have a 172 in it but I would like to make sure the engine is correct.
Thanks again for the help, Bob
Scott
10-21-2003 16:32:31
Ford would have used a number like 310000 during the late 1957-1959 date range, then from 1960-1964 it would have been a format like C0NN6000A.
