hydraulics
BRL
10-22-2003 07:23:07
I asked earlier about the difficulty and expense of auxillary hydraulics. What I am wanting is the auxillary hyd under the seat on a ford 650 to use for a baler and mower to raise and lower the tires for example. Thank you for your help.
Dan Robertson
10-22-2003 07:32:10
 Re: hydraulics in reply to BRL, 10-22-2003 07:23:07
Check with your local, or internet tractor salvage yards for the remote valve/valves. That's where I located the one for the 2000 Ford. Cost me $170.00 though. Dan Robertson
paul
10-22-2003 09:09:19
 Re: Re: hydraulics in reply to Dan Robertson, 10-22-2003 07:32:10
That sounds cheap, actually!
There are several different options. Been some good pics & explinations on this forum the past 2 weeks, if you look back, all the 100 series are basically the same.
Do you have anything there now, sometimes bits & pieces are already on the tractor. Some sort of plate & a lever or 2 go under the seat. Need to decide if you want 1 or 2 remotes.
--->Paul
