automobile power steering pump to use with Behlens
aaron
11-05-2003 10:04:57
I am learing how to piece together a power steering setup for an H Farmall.
I have access to a Behlens motor. It will hook into the Belly Pump but will not be live with the cluth disengaged. So, I learned that a fella could go to a auto salvage yard and choose a power steering pump driven off the fan belt to be the power source and reservoir for the Behlens unit. Any ideas on what I should look for. i.e. F150 pump, Mazda pump, ...
Mike
11-08-2003 06:13:56
 Re: automobile power steering pump to use with Beh in reply to aaron, 11-05-2003 10:04:57
Aaron,
If you're looking for a pump that should handle the stresses placed on it by the Farmall H, the F-150 pump should be strong enough to shoulder the load, it's built to overcome the strain imposed by 2500 lbs dead weight sitting on the front wheels, so I don't think the H is going to overstress it. Good luck.
Mike
