Rear End Vent
al from Virgini
11-19-2003 13:08:47
I was wondering if there is some sort of vent on the rear end of my Ford 3000 1966 tractor... I just did a brake job and would not like to do this again, almost every vehicle (with a rear end) I looked at, had some sort of vent, including my Motorcycle... So if someone could let me know if there is one on my tractor, and where to find it, I would appreciate it...
Scott
11-19-2003 18:29:23
 Re: Rear End Vent in reply to al from Virginia, 11-19-2003 13:08:47
it is either under the seat with a cap on top or one of the 3 bolts is drilled that holds the draft control spring plunger rod in place behind and below the seat.
al from Virginia
11-22-2003 17:08:15
 Re: Re: Rear End Vent in reply to Scott, 11-19-2003 18:29:23
Scott,
Well, I looked all over that rear end. Not one vent or hollow bolt could be found… Even removed the seat for a better look. I also talked to the New Holland Service Man… He don’t remember seeing one. I know, not seeing and knowing is different. But I am still at loss.
Al
al from Virginia
11-19-2003 19:46:30
Thank you for the quick response, I will have to look... al...
paul
11-21-2003 16:19:03
 Re: Re: Re: Rear End Vent in reply to al from Virginia, 11-19-2003 19:46:30
I'm so glad you got a serious reply. I read your title & message shortly after you posted it, & just had to walk away from the computer chuckling..... ;)
--->Paul
forworkma
11-21-2003 18:09:58
 Re: Re: Re: Re: Rear End Vent in reply to paul, 11-21-2003 16:19:03
great minds think alike..... ..
