Order Ford 3000 Parts Online
1965 3000 pwr steering part??
Bill
12-07-2003 19:12:42
need to find a adaptor assembly, gear... part number 86570855.. this is a small housing that goes just above the steering box, but below the power steering valve assembly...
This part is on 2000, 3000 and 3400 with power steering... If anyone knows were I can find one, please let me know. Mine is cracked at the oring housing. Thanks Bill
Sam MI
12-08-2003 05:58:57
 Re: 1965 3000 pwr steering part?? in reply to Bill, 12-07-2003 19:12:42
I suspect you need; P/N310869, Union Hydraulic valve return. Try your New Holland dealer or check with a local automotive dealer.
bill
12-08-2003 06:27:41
 Re: Re: 1965 3000 pwr steering part?? in reply to Sam MI, 12-08-2003 05:58:57
no, its actually part of the steering box that goes around the steering shaft. but it is the housing that is in between the steering box and the actuall power steering valve housing. this housing is call "gear adaptor assembly becuase it allows the normal steering box to be adapted to power steering.. thanks bill
