Ford 641 question?
Ben
12-08-2003 07:34:30
Does anybody know much about the Ford model 641's? I've come across one with ser # 108368.It is still 6 volt.Does anyone know if it is a positive or negative ground? He has it hooked up negative ground and it's not charging.I think he might have messed up and hooked it up wrong.If so, what could be bad now?
Jim.UT
12-08-2003 09:57:23
 Re: Ford 641 question? in reply to Ben, 12-08-2003 07:34:30
The 641 should be positive ground if it's still the original 6 volt setup. I'm not an electrical expert, but I would think you would want to repolarize the generator at the very least (after getting it hooked up correctly).
Don M
12-09-2003 05:13:47
 Re: Re: Ford 641 question? in reply to Jim.UT, 12-08-2003 09:57:23
I have a 641 and it is a great tractor; easy to work on and very dependable. I agree with Jim on the electric; there could also be a problem with the generator. The electrical system is fairly simple overall. I bought my 641 through a local NH dealer who was selling it for a client. The lights didn't work and part of the deal was to make them work. The NH dealer wound up totally rewiring the tractor and replacing the generator to get the lights to work! Good for me! Don
