Ford 641 stopped running,
Barb
12-08-2003 14:41:01
My 641 started fine, ran about 5-10 minutes, then stopped cold. Turned the key switch off then back on, pused start button, and got absolutely nothing. Any ideas where to start?
Dave H
12-10-2003 03:20:25
 Re: Ford 641 stopped running, in reply to Barb, 12-08-2003 14:41:01
You didn't mention if it was cranking or just not statring, but if it is cranking the first things to check are spark and fuel. If no spark first suspect is the points also see if there is power coming in at the coil on the positive side.
John A (TX)
12-09-2003 13:44:04
Fuel shutoff value open?
raytasch
12-08-2003 16:47:09
Battery cables.
ray
