Well wheels fit ?
AJ in Va.
03-28-2001 13:49:39
I have a chance to buy a pair of used rear wheel rims for my Ford 3000 gas 1965 model, but they are off an international. In a parts catalog they both use the same parts number if I would order them. I hope I'm not making a mistake. They both are for a 12.9 X 28.9 tire and i measured the bolt holds and I think they will fit. Have any of you out there used IH rims on a ford or the other way around?
Jerry D in NC
03-28-2001 19:22:52
 Re: Well wheels fit ? in reply to AJ in Va., 03-28-2001 13:49:39
Well I guess I will read the next post closer before I go running off to check. I have an IH 460 that has 28" wheels and I had to replace the hub on the tractor last year. Well to make a dumb story short the wheel will not fit. The rim might, I haven't checked that yet but I will in the morning. The center hole is larger and the lug pattern is a larger diameter.
AJ in Va.
03-28-2001 21:08:19
 Re: Re: Well wheels fit ? in reply to Jerry D in NC, 03-28-2001 19:22:52
Jerry, what I mean is will the rims fit the wheels on a Ford if the rims came from a IH.
The guy who is selling them to me is giving me a great price. I'm only hopeing I don't make a mitake.
Jerry D in NC
03-30-2001 04:19:02
 Re: Re: Re: Well wheels fit ? in reply to AJ in Va., 03-28-2001 21:08:19
I measured again and I can not see a difference either. But again, I would call the manufacturer and ask him. There might be some differences in different manufacturers wheels.
