post hole digger
billdorrance
12-29-2003 20:00:17
will a naa run a post hole digger ok, like one from tranctor supply??
how big of an augger will it turn??
Phil(va)
12-30-2003 15:50:35
 Re: post hole digger in reply to billdorrance, 12-29-2003 20:00:17
As others said, it will work fine, if soil isn't too compact or too much rock and shale. If you break a shear bolt, replace with grade 5, not grade 8, to protect the shaft.
Bob Semrau
12-29-2003 20:58:55
An NAA is much better with a post hole digger than an N, as it has live hydraulics. It will do a good job. Mine has a 12" auger and I haven't had any problems running it with my NAA.
John A (TX)
12-30-2003 08:46:02
 Re: Re: post hole digger in reply to Bob Semrau, 12-29-2003 20:58:55
I agree: The NAA shouldn't have a problem, though that might depend on the soil. Back when I had my 8N, I used a friend's posthole digger on really sandy soil - 9" or 12" auger, I think - and didn't have a problem until I got down into some red clay! I learned to take smaller bites, but it worked fine.
HTH
~ja
