Air Filter
BigWill
01-04-2004 16:25:42
Hello All
Does anyone Know if there is a dry element filter available to repalce the metal screen/oil bowl filter on my ford 4000. I hope New Holland make a replacement filter without having to change the housing.
Thanks,
BigWill
RickB
01-05-2004 03:32:18
 Re: Air Filter in reply to BigWill, 01-04-2004 16:25:42
You will need a different housing, or engineer the changeover yourself.
Jerry/MT
01-07-2004 15:17:39
 Re: Re: Air Filter in reply to RickB, 01-05-2004 03:32:18
Rick, I don't think there is a replacable filter. If yours is dirty you can clean it relatively easy. Pour some solvent (Paint thinner, laquer thinner, diesel, etc) in a five gallon bucket, take the oil cup off and empty it. Place the whole works in the solvet making sure that the whole unit is covered by the solvent. Leave it for a day or two. Empty the solvent from the filter unit, pour a little of the solvent into the filter housing and swish it around a few times. Repeatseveral times. Look inside and see if the steel packing looks clean. If it doesn't, put 'er back in. If the solvent is really filthy, replace the solvent and repeat until the packing looks fairly clean. Then let it dry, re-install, put oil in the cup and fire it up. By the way remember to replace the oil in the cup regularly. That's what causes these types of filters to get clogged up; running in really dirty, dusty conditions without changing the oil in the cup. The oil catches the dust and dirt and cleans the packing so it needs to be repaced regularly.Hope this helps.
