FLUID LEVELS IN GOLDEN JUBILLE
BK IN PENNA
01-09-2004 05:12:30
I BOUGHT A GOLDEN JUBILLE,AND I WANT TO CHANGE THE OIL IN THE REAR,TRANS,HYDRUALICS.THERE ARE 3 CAPS,ONE NEXT TO THE SHIFTER,ONE UNDER THE SEAT, AND ONE ON TOP OF THE REAR. WHAT GOES IN,AND HOW MUCH? I ORDERED A MANUAL, BUT I WANT TO GET STARTED. THANKS BILL K
Dave H (NY)
01-10-2004 04:55:18
 Re: FLUID LEVELS IN GOLDEN JUBILLE in reply to BK IN PENNA, 01-09-2004 05:12:30
Bill, you can use the New Holland 134 hydraulic oil in the entire tractor (except the engine) You have a sight plug on the side of the rear end to check the fluid level, filled from the top of the differential. You have a sight plug on the right side of the trans, filled by shifter. and you have the dip stick for hydraulics filled under the seat. It will use about 5 gallons in all.
Bill K
01-10-2004 07:01:29
 Re: Re: FLUID LEVELS IN GOLDEN JUBILLE in reply to Dave H (NY), 01-10-2004 04:55:18
Thanks Dave, Ill get to work.
