Vacuum Line identification (Ford 1720)
Brad Bauer
01-16-2004 16:53:30
Just bought a 94 Ford 1720 and am trying to fix the jury-rigged things the previous owner did. I found 2 vacuum lines coming out of the firewall on the right side. One goes to the fuel shut-off valve, the other goes to nothing. Any idea what it should be going to? I see pictures in the shop manual with the 2 vacuum lines coming out but nowhere does it describe where they're going.
Thanks,
Brad
p.s. Tractor seems to run fine though.
Jerry/MT
01-17-2004 14:12:48
 Re: Vacuum Line identification (Ford 1720) in reply to Brad Bauer, 01-16-2004 16:53:30
Doesn't the 1720 have a diesel engine? If so, there ain't no vacuum lines, unless you have some sort of a vacuum pump.
RickB
01-16-2004 18:04:50
one is a bleed line from the fuel filter head. The other goes to the fuel return connection on the number 3 fuel injector.
