JUBILLE-DIFFERENTIAL CENTER HOUSING
BILL IN PENNA
01-24-2004 03:45:05
Is the center housing on the jubille the same as the 8n?
Jim.UT
01-24-2004 17:45:50
 Re: JUBILLE-DIFFERENTIAL CENTER HOUSING in reply to BILL IN PENNA, 01-24-2004 03:45:05
John Bower probably has one, too, but Wenger's would be way closer to you.
Roger
01-24-2004 04:10:33
Nope. The critter you are looking for is unique to the NAA series (1953-1954). The hydraulic pump and the routing of the service lines to the lift piston make this different than the hundred series. 8N's had pump in the belly, way different beast. Good luck on your hunt.
Roger
