hydraulics
Bob
01-31-2004 19:57:54
I have a 70's model Ford 5000 that has to be warmed up for about 10 minutes before the rear hay lift will work. It may be low on hydraulic fluid but I am not sure where to add the fluid or how to check the level. Signed I GUESS I NEED A MANUAL.
John IA
02-01-2004 12:41:05
 Re: hydraulics in reply to Bob, 01-31-2004 19:57:54
Bob, as cold as it's been I'd jump for joy if my tractor was warm enough to lift a big bale in 10 minutes. It probably has heavy oil in it. Should be a dip stick under the seat left side down at bottom edge I beleive.I think the fill hole is under the seat to. I'm not sure I've only been on 1-5000. John
