555 Temp Sender
Allen
02-05-2004 16:53:51
Was recently changing the alternator on my 555 and found a loose wire when complete. All wires are correct on the alternator so it must be for the temp sender. It is bundled with the main alternator wire. It has a flat female connection, but I can't find the male that it connects to. Where does it connect? Thanks for any help.
Dana NC
02-07-2004 14:22:48
 Re: 555 Temp Sender in reply to Allen, 02-05-2004 16:53:51
The wire you are looking at is a wire to feed the front head lights. It is not used on your machine. HTH Dana
Allen
02-09-2004 17:27:06
 Re: Re: 555 Temp Sender in reply to Dana NC, 02-07-2004 14:22:48
Thanks much for the help. I thought it was clean to have been attached anywhere on the engine. Allen NC also
