F150 acting strang
7783e
02-08-2004 20:32:00
I have 1986 Ford F-150 with the 302 (5.0)
It was running just fine when I shut it off but when it came to start it, it turn over and lop in and out of compression and some times it will hit but never crank .
Pleas help me its my grandfathers truck
DAVID
02-11-2004 09:23:05
 Re: F150 acting strang in reply to 7783e, 02-08-2004 20:32:00
I had the same thing happens on my '85 f-150.
I thought I had a blown the motor. Turns out the fuel modulator seal had ruptured allowing my cylinders to fill up with gas. The motor was "hydraulicing" the cylinders not allowing the pistons to compress. Try taking out all the plugs and see if there is evidence of gas on plugs or in cylinders.
good luck!
Phillip
02-09-2004 21:20:14
Think about it when you turned it off. Did you happen to hear a metallic ping or clang? My 289 did this years ago. It jumped time. That is, the timing chain jumped one tooth. It sounded just like you described during cranking.
ken in wisconsin
02-09-2004 06:51:48
If this only happens when the engine is hot (just recently shut off), I would suspect the culpret is heavy carbon deposits. When you try to restart, the carbon is igniting the fuel mixture well early in the compression stroke, and your starter is fighting against it. If your problem happens when the engine is stone cold, look for the problem elsewhere.
Chris
02-08-2004 21:13:08
If I understand what you are saying ,the starter will not turn the engine over (crank) but it will rock the engine up to compression and then fail to turn it over(lop in ond out of compression). Sounds like a dead battery , bad battery connections/cables or a bad starter. Clean the battery terminals first. Then try jump starting it. That should point you in the right direction.
ray
02-11-2004 12:30:24
 Re: Re: F150 acting strang in reply to Chris, 02-08-2004 21:13:08
It your grandfather is around ask him if he knows what wrong with it --you'll be surpised how well people know there equipment after owning it for that long.
If its been sitting and it has gas in the cylinders like one poster said check your oil for gas in it. If present change your oil.
