 The picture is from the Ford manual for my 4000 series S-O-S. The input shaft spline is to the left of the oil pump at the far left, the direct drive clutch far right. The gears and parts on the input shaft between bearing "B" and bearing "R" are not in my transmission, as it has no PTO. Oil flows from the pump through passage "M" to the distributor. The passage "D" supplies oil to the direct drive clutch when it is engaged. I a transmission with PTO, oil supplied by from the right by lube passage "L" would flow out of the journal at "P" and oil the bearing "B". On the NON-PTO version, the lube passage "L" stops about where I put the "L". While bearing "R" should get a good supply of oil from the front direct drive clutch journal, (below and right of the "R") The only oil that bearing "B" gets is what can leak past the seal "S" that directs the oil to the direct drive clutch. (only supplied while clutch is engaged) Thanks again, Dave
