172 casting numbers?- Tony Jacobs-need help
Barney in Ga.
04-06-2001 07:58:33
I need to know what engine these casting numbers are on,the year, and model if possible. CONN6015J . I want to buy it to put in my 851 if it's correct. It came out of a Balmar D-60? Whatever that is.
Thanks; Barney
Barney in Ga./THANKS!
04-08-2001 13:28:37
 Re: 172 casting numbers?- Tony Jacobs-need help in reply to Barney in Ga., 04-06-2001 07:58:33
Thanks for the help everyone, I don't know if I'll be able to get the numbers you were referring to, Tony, but thanks anyway! Barney
Tony Jacobs
04-07-2001 21:06:50
Hi Barney , That casting number is good for 1960 - 1965 Tractors , but the date of that particular block is on the left front corner just above the oil pan rail , if you post that number I CAN TELL YOU WHAT YEAR THAT BLOCK IS . THANKS TONY JACOBS
Rod MI
04-12-2001 19:38:57
 Re: Re: 172 casting numbers?- Tony Jacobs-need help in reply to Tony Jacobs , 04-07-2001 21:06:50
Tony Jacobs have you thought of writing a book and putting all of your knowledge of the ford tractor in it? You seam to now information about the ford tractors that the dealers don’t even now and I now you now more then mine dues on the S.O.S transmissions and could you tell me what year my block is thanks rod( 2G10 ) 172 gas
Tony Jacobs
04-13-2001 22:02:45
 Re: Re: Re: 172 casting numbers?- Tony Jacobs-need help in reply to Rod MI, 04-12-2001 19:38:57
Hi Rod , Thanks for the kind words , I just try to help out the best I can , I guess the knowledge comes from so many years experience with them . Your block is July 10, 1962 , Casting number should be CONN-6015-J . Thanks Tony Jacobs
Rod MI
04-14-2001 21:37:53
 Re: Re: Re: Re: 172 casting numbers?- Tony Jacobs-need help in reply to Tony Jacobs , 04-13-2001 22:02:45
YOU ARE CORRECT ON THE CASTING NUMBER THANKS
George H
04-07-2001 20:28:21
hi Barney,
David Tiefenbrunn has a Balmar loader/backhoe which is a skid steer machine utilizing a Ford drivetrain. David has been in a running battle for several months with the Select-O-Speed transmission in his Balmar. The 801 series came out 1958 and the S-O-S became available on the 801 Series in 1959, which would indicate there's a good probability the engine is a match for your tractor. By coincedence, David posted "SOS Technical Question" about three posts below yours. You might reply to his post with your question. I'm sure he'll be willing to check his engine casting numbers. David's website is at the link below. Not much help I'm afraid, but maybe better than nothing.
regards,George
Rod Mi
04-07-2001 12:55:19
Barney 172 4cyl gas 1963 ford 4000 and it should be the same for any 100 and 1000 sires I think
