Order Ford 600 Parts Online
Ford 600 Fuel Shut Off Valve
David
03-03-2004 03:21:50
Any new technology on a better shut off valve? Mine is about 3 years old and has started to leak?
Tom Anderson
03-03-2004 17:40:15
 Re: Ford 600 Fuel Shut Off Valve in reply to David, 03-03-2004 03:21:50
third party image
You can take that rivet out of the bottom, take the valve stem out, replace the o-ring, and put the rivet back applying JB weld to hold the rivet in place. Or buy a new assembly and hope that one doesn't work.
Tom
Mark
03-04-2004 06:12:47
 Re: Re: Ford 600 Fuel Shut Off Valve in reply to Tom Anderson, 03-03-2004 17:40:15
Super reply Tom. Next time I will do this and save the $45.
Adding to your post:..... ., or, just remember to only open the petcock 1/2 to 1 turn and you don't have to fool with the rivet....right?
Mark
Rod M1
03-03-2004 07:56:45
You can install a ball valve in line. I have had this set up for about 3 years and I never have problems with it. But it will take some rerouting of the fuel line. The way I routed mine isn't the grates way and I plan on changing it eventually but the ball valve will stay.
Mark
03-03-2004 09:20:02
 Re: Re: Ford 600 Fuel Shut Off Valve in reply to Rod M1, 03-03-2004 07:56:45
Don't understand your solution, Rod M1.
My fuel shutoff valve is attached to the bottom of the tank and the first thing in the fuel delivery system. If it is leaking (now I'm understanding that the leak is external, not internal)you can't get anything between it and the tank. However, if it is allowing gas to flood the carburetor due to an internal leak, then I agree with you.
My problem was external leaking.
Mark
Rod M1
03-04-2004 08:50:36
 Re: Re: Re: Ford 600 Fuel Shut Off Valve in reply to Mark, 03-03-2004 09:20:02
You would have to remove the valve and tap the hole that is in the tank. All the after market tanks are that way. But if you have to do that you are probable better of buying a new tank and using a N series sediment bowl and taping into the right side fitting on the new tank. You will quickly save money from not having to buy $50 valves every 6 months just my 2 cents. I will try to post some pictures of what I did But the pluming isn't very good for flammable products. But it should give you a general idea of what I mean.
Rod M1
03-04-2004 09:01:07
 Re: Re: Re: Re: Ford 600 Fuel Shut Off Valve in reply to Rod M1, 03-04-2004 08:50:36
You will have to figure out the pluming but this is what I did some of the fitting aren't rated for flammables sow you will have to use something to plum the system.
Link
Mark
03-03-2004 05:55:22
I pondered the same question when I found out that the replacement was $45 at an after market house no less. After fighting my "Scottish ancestry" for some time and analyzing all the things associated with it that had to be delt with, I couldn't wiggle out of the deal and had to spring for the O.E.type.
Good luck.
Mark
