Order Ford 860 Parts Online
860 hydraulics not working
Brad Ball
03-07-2004 12:45:08
'55 Ford 860 w/ vane pump had been working fine all winter. Changed water pump, oil pan gasket,oil filter, plugs, wires etc, this weekend. Started 'er up and sounded great, except now the hydraulics aren't working. I've searched for info on bleeding vane pump but really can't find much. I want to cover all the bases before I endure the cost of changing to a piston pump. Any help would be great on bleeding (if necessary)or anything else that may have caused this. (Fluid isfull and not real bad).I plan on changing the fluid TOO< but it was working in the dead of winter fine. THanks in advance. bball
Dave H (NY)
03-09-2004 03:45:47
 Re: 860 hydraulics not working in reply to Brad Ball, 03-07-2004 12:45:08
Brad I am in the town of Montgomery in Orange county. y e-mail is childebrand@hvc.rr.com
Dave H (NY)
03-08-2004 06:12:32
Brad, I have a 1955 850 with the vane pump, same problem. What I have to do is turn the bleeder valve (on the end towards the distributor) until the cap comes off, then I push my finger against the plunger inside (while the tractor is running) and usually after a minute or so of fussing with it it starts pushing the oil out and is fine for weeks after that. I also have a 1956 860 and it has the piston pump, a much better setup never have problems, if I ever run across a piston pump and manifold when I have an extra $400-$500 to buy it with I will.
bball
03-08-2004 17:42:11
 Re: Re: 860 hydraulics not working in reply to Dave H (NY), 03-08-2004 06:12:32
Thanks Dave. I'll get to try all these options on Wednesday. I'm in the same boat w/ the $400-500. I'm also in NY, down by Greenwood. How about you?
Royce TN
03-07-2004 17:41:53
Sory, I posted the wrong link, try this one.
bball
03-07-2004 19:50:14
 Re: Re: 860 hydraulics not working in reply to Royce TN, 03-07-2004 17:41:53
Royce TN Thanks a ton. I'll be trying all the options . Hopefully it's just the prime. Thanks again.
Royce TN
03-07-2004 17:37:04
Brad, try this link. It was a discussion from back in November. Hope it helps.
Mark
03-07-2004 14:54:11
Brad, do we work together in McK? 0032293. If so, pluck me out of directory services. Will talk.
Mark
bball
03-07-2004 16:14:48
 Re: Re: 860 hydraulics not working in reply to Mark, 03-07-2004 14:54:11
I don't think so. I don't know what McK is.
Mark
03-08-2004 05:43:46
 Re: Re: Re: 860 hydraulics not working in reply to bball, 03-07-2004 16:14:48
If you were you'd know. I work with a Brad Ball and if you were he, it would surely be a coincidence i.e. small world. Thanks for the reply.
Mark
McK is the abbreviation for a town where I work.
