Order Ford 3000 Parts Online
3000 Ford Tractor
Gary Smith
04-09-2001 09:17:50
I'am working on a 3000 tractor and I have hyd. oil leaking from a bolt or plug that is right under the hyd.check plug.It is loose in the hole. It won't tighten up I pulled it out and it will just pull in and out. Is it a low check plug?
Jim Nichol
06-13-2004 06:05:29
 Re: 3000 Ford Tractor in reply to Gary Smith, 04-09-2001 09:17:50
I have a 3400 Ford Tractor with a damaged cyl. head. I am able to find heads marked 6090AA, but not the ones on mine, which are 8590AA. Are these heads compatable, or where can I find a head that is a compatable replacement?
Thanks, Jim
Roy B
04-10-2001 08:19:07
Gary I believe the bolt you are speaking of holds the pick-up for the hydraulic pump. If you remove the inspection cover from the similar location on the opposite side of the differential housing, you can reach accross and line up the pick-up with the hole. Have a second set of hands thread the machine screw back in through the case and into the mounting tab on the pick-up. You will need a new gasket for the inspection cover, a good light and a fair bit of patience. Good luck. Roy
