Order Ford 601 Parts Online
loader for 601
Berger
03-08-2004 18:47:59
I purchased a loader that was said to fit '46-59 8N&9N it looks like it bolts up in the same spots as my 1959 661 the only difference that i might have a problem with is the shaft that runs the hydr. pump goes into the crank pulley. I have the pulley from the 8n the loader was on but the offset is different so the belt would not run my alt. does anyone know what i could do.
Mark
03-13-2004 08:21:36
 Re: loader for 601 in reply to Berger, 03-08-2004 18:47:59
If you have access to a welder, fabricate a new bracket for the alt.
What about the fan? Is it dual pulley? IF not, what good will moving your alt do?
Mark
