Thanks to Dave H. and Royce TN
bball
03-10-2004 16:06:14
I got my hydraulics back today. Thanks fellas. I started w/ blocking up the back end, but no luck. I then tried a little air thru the dipstick, still no luck. I finally pulled the Flow control cap and spring and pulled the plunger out. I had no fluid in there. Put the plunger back in and worked it back and forth , in about 3-5 minutes, it started spitting fluid, put it back together and I'm back in business for a while. I'd like to go to a Piston pump eventually, but I really need the Vane pump to work until I can afford to make the transition. Thanks again! Brad
