PTO
Al R
03-14-2004 18:04:49
I have a 871 Ford with select o speed. The PTO doesnt want to disengage. Is the ajustment in the cable itself? Thanks
Geo in SD
03-15-2004 04:41:11
 Re: PTO in reply to Al R, 03-14-2004 18:04:49
Are you thinking the pto is not disengaging because the shaft turns all the time, whether the t-handle is out or in? It is normal for these to turn in disengaged mode because of oil and clutch plate drag. Stick a 2x4 against the shaft and pry against the lift arm, if the shaft stops turning, it is disengaging. If it doesn't stop, the problem is in the cable adjustment, valve, or warped plates in the clutch.
