Order Ford 661 Parts Online
Fuel tank removal (Fordd 6610 w/cab)
ALEX
03-22-2004 09:59:18
Anyone know the best way to remove the fuel tank from a 1985 Ford 6610 w/cab, without removing the cab? I thought it may come out through the inside of the cab, but not sure. It looks as though some panels around the tank may be part of the cab (i.e. not removable).
JHEnt
03-22-2004 18:00:30
 Re: Fuel tank removal (Fordd 6610 w/cab) in reply to ALEX, 03-22-2004 09:59:18
remove the cab or split the tractor at the clutch housing. You can remove the dash to replace the fuel sender but thats about it without lifting the cab. Personally I would rather split the tractor.
ALEX
04-07-2004 10:18:10
 Re: Re: Fuel tank removal (Fordd 6610 w/cab) in reply to JHEnt, 03-22-2004 18:00:30
Thanks. I tilted the cab back on the rear bolts after taking the necessary rods and hoses loose. It wasn't near as bad as it looked.
